Author Topic: aftermarket adjustment kit  (Read 622 times)
« on: June 09, 2001, 09:36:24 PM »
apexiR
(11/15/00 10:08:10 pm)
Reply  aftermarket adjustment kit
 there are camber and castor adjustment kit for skyline
on the market
when u go for a wheel aligment , there are only little adjustment allowed in facotry suspension setup
the onlything u can adjust in skyline is the "toe"
if aligment readout still not right, the shop would probably suggest u to buy a kit to solve the problem
u might get nice figure after fitting the kit
however the worn parts that causing wheel aligment to go wrong at first place are still worn and need to be replace
a worn bushes will let u run 1 degree more negative camber, a worn joint will screw up ur
cators,cambers,toe
those kit are designed to allow adjustment on "perfect" working suspension , not demaged one
just be aware
if the reason for u to buy them is to run more camber to improve handling or reduce camber after lowering cartoo much, that is alight
if ur alignmnet is not right at the first place , and u wanna buy that to correct ur wheel alignmet, then it is a big "NO NO", u better track down the demage parts and replace them first
have wheel aligment problem ?
let me know , i am glad to help
