Author Topic: How to communicate with a R33 Skyline ECU  (Read 46456 times)
mot
« Reply #150 on: May 22, 2005, 08:32:13 AM »
NewKleer
« Reply #151 on: May 22, 2005, 02:47:18 PM »
that doesnt work on pocketpc
1madkiwi
« Reply #152 on: May 22, 2005, 03:03:38 PM »
bummer
mot
« Reply #153 on: September 21, 2005, 06:49:21 AM »
hi guys i have a nissan consult 1 lying around in very good condition / any one?
David Kemps
« Reply #154 on: September 21, 2005, 10:05:50 AM »
yeah, how much do you want for it?
where are you located?
Dave
Keeper
« Reply #155 on: September 21, 2005, 01:07:55 PM »
the propper nissan one?
NewKleer
« Reply #156 on: September 21, 2005, 05:33:19 PM »
does it have any cards (and does it need them, or is that consult 2?)
mot
« Reply #157 on: September 28, 2005, 05:14:14 AM »
hi/guys its a consult 1 theres no cards but its loaded up with 98 software so it covers all obd 90----98 its in good working order with the lead i also have a 94---v1-2 nats card for it [whitch consult 2 cant do!!!] but id rather keep this card
sensible offers please
ps all new batterys!!
mot
« Reply #158 on: September 28, 2005, 05:18:36 AM »
its consult 2 that needs cards to operate this 1 doesnt need card as its in the memory
« Last Edit: October 17, 2005, 12:11:22 AM by mot »
NewKleer
« Reply #159 on: September 28, 2005, 09:59:02 AM »
u cant expect a sensible offer without defining what that is...
mot
« Reply #160 on: September 29, 2005, 01:26:51 AM »
fair enough your right ill ebay it the reserve will be $125 ad
cheers
mot
mot
« Reply #161 on: October 17, 2005, 12:09:15 AM »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8007615263&ssPageName=ADME:L:LCA:UK:31
i started it low price but its going up im afraid
ps found rest ov kit aswell :)
« Reply #162 on: August 29, 2009, 09:09:02 PM »
First update in 4 years! I have just bought the V2 display from http://www.ecutalk.com which i believe is the product of New Kleer above. It is a small screen which would fit in a din slot and communicates via the consult port with my R32 and Stagea ecus ( I have both) just fine. For those like me with a 180 km'hr speedo it has a speedo reading and will hold the max values so after my stint on the track i can see that I reached 188km/hr on that lap. It is ideal for someone like me who doesn't have a laptop. It displays the main sensor functions (tps, temp. voltage, etc etc) and also has a trip computer function with distance travelled speeds etc and you can enter the number and size of your injectors and it will read fuel consumption in real time. It also gives the fault codes in English so instead of counting flashes it says code 23 faulty temp sensor (hope I got the code number right) started 14 times. For something over $200 for a basic scan tool I think its great. It also has a usb port in the front so that you can use the supplied cable to connect to a laptop if you have one (and for firmware updates)
« Last Edit: August 29, 2009, 09:11:48 PM by westybob »
VQ30STAG
« Reply #163 on: July 23, 2010, 08:37:52 PM »
Hey mate, where would I find a consult port on a Stagea?? I have no idea where anything is on my car!
Quote from: westybob;486296
« Reply #164 on: August 16, 2010, 03:08:56 PM »
Quote from: VQ30STAG;502564
Sorry mate - only just noticed this post. In the S1 Stagea the consult port is beside the fuse box (pull out the coin tray to see it). I think the M35 models like yours don't use consult anymore but the more general OBDII standard.
