« Reply #6 on: March 11, 2012, 10:26:41 PM »
With the brakes would I just need front 4 pots or front and rear upgrade?
You would probably get away with your stock brakes with up graded pads and fresh fluid, if you are wanting to go to bigger calipers and rotors you could always use R33 GTS25 front calipers and rotors, the front calipers are 2 pot, and the rotors are 280mm diameter and 26mm thick. The best thing about them is they are 4 stud so are fairly easy to fit.
Logged
Taupo track 1, 1.56 (A1GP)
Taupo Track 2, 1.23
Taupo track 3, 47.89
Taupo track 4, 2.02
Manfeild, 1.30
Pukekohe, 1.17
Hampton Downs, 1.25
