Author Topic: Sealing windows in R32?  (Read 1125 times)
Drift-monkey
« on: October 27, 2015, 06:42:11 AM »
How have you guys done it? Hate washing the car with a water blaster.. or even just a hose cause just pours water through the windows... as far as I'm aware new door seal/rubber is discontinued.. is it a case of finding a good second hand seal or is there a trick to it? Any help appreciated.
Re: Sealing windows in R32?
« Reply #1 on: October 27, 2015, 09:01:40 PM »
Do you have a 2 or 4 door? What seals are you specifically talking about?
I have some door seals from a 4 door you can have if they're right for you
« Reply #2 on: October 27, 2015, 09:20:07 PM »
From a 4 door R32. They're yours if you can put them to good use  :)
Drift-monkey
« Reply #3 on: October 27, 2015, 10:07:36 PM »
Door/window seals yeah. Exactly what I was looking for and need, 4door also. Sounds good, will definitely be put to good use! I'll give you a yell sometime in the weekend if that's all good? Will be going on this heap
