Author Topic: Bolt leaking above cylinder 1  (Read 666 times)
dirty_25det
« on: October 23, 2016, 08:39:30 PM »
Hi everyone. Ive got a 25det that has a leaking allen type bolt above cylinder 1 pretty annoying cause its overflowing into the spark plug making it misfire. What is this bolt. if i take it out does it need to be put back with a toque wrench and what should i do to seal it ? any help would be really awesome cheers
Sky756
Re: Bolt leaking above cylinder 1
« Reply #1 on: November 27, 2016, 08:56:17 PM »
Hi, this plug-tread of head cooling channels, you can unscrew and screw back with gasket seal, should be checked for cracks around the plug
